Arena NDI not showing in sources
heronick
Post by heronick »
I have a weird problem 2 days ago this worked fine but since today NDI is not showing up in sources anymore the spout server is but ndi is not i tried to remove all the files and a clean install but its still not showing up and yes its active in the output tap.
Re: Arena NDI not showing in sources
Sounds like a firewall issue to me.
Did you get any windows updates in the last few days?
Installed NDI tools, or Access manager?
heronick
Post by heronick »
i did install NDI tools and Access manager but removed them again
Was this around the time NDI got broken?
heronick
Post by heronick »
Yes i also want to add i made a fresh windows acount and it works fine on there
Weird.
Could be that some remains of the access manager still loads on startup with wrong settings in the other account.
Do you see the arena source in other apps with the account?
How about on another machine on the same network?
