Hi everyone
I have a Pioneer Sx2 midi controller that is being used with Traktor via USB.
I'm trying to map my midi notes to Resolume 6 with the Sx2 while also trying to run Traktor 2.0.
However if Traktor is running and I try to select the controller in resolumes 6 preferences and select "midi in" it then says midi device in use.
If Resolume 6 is running and I attempt run Traktor, Traktor will just say no midi device found.
Is there a setting within the Sx2 that will allow both software to communicate with the controller?
Thank you very much!
