gpvillamil wrote:Hmmm - so I guess this is especially useful when the parameter is animated, since you can specify the range?
Otherwise, if you're just updating the value sending, say, 0.5 is the same as sending 0.0 0.5 1.0?
The BPM does work, very smoothly, thanks!
Yes the in and out points are indeed usefull when animating, of course the timeline of the clip is the most obvious case.
Just sending 0.5 is not exactly the same as sending 0.0 0.5 1.0 as the latter would set the in and out points too and would reset any changes you might have done to the in and out points. Just sending 0.5 only updates the current value.
If you only send 1 value the value is also relative to the in and out points, so if your inpoint is set to 0.2 and your outpoint to 0.8 you can still just send values between 0 and 1. Hope this make sense.
