1. Copy your long clip three times in your clip deck
2. Trim each clips to the size/duration you need
3. Freak-Out because in that case you can add different effects to the clip parts...
4. Freak-Out again because it's all midi mappable.
Perhaps related but I'd like to see a marker system globally across all sliders which could be used for beat markers, cue points and clip parameters with options to jump to markers and stop or continue (until the next beat).
Mockups always tickle our fancy, but I'm not quite sure how those markers relate to the beats? Do you jump to them on every beat? Do markers get added and removed when you change the amount of beats?
