Hi guys, just wanted to know if there's a update of the section of arena for the mapping.
It's pretty powerfull, but some minor tweaks would make it awesome . Mainly the option to zoom in or out of the output window.
When you are working with super tiny slices on a triplehead2go windows, it's basicaly impossible to work with. to select the points, or try to put you cursor in the center of the slice to transform it
Also the possibilty to do Input slice in other shape than rectangles would be nice . Its a bit of a pain to use if you have mapping area that are overlapping.
Thanks again
