Advanced Mapping Feature
MikeDubsDC
Post by MikeDubsDC »
PLEEEEEASE Add the ability to zoom in on grid points within the Advanced Mapping/Warping screen!!! This is my only gripe with this software. On more advanced shows I almost always have to Cyphon Resolume through MadMapper in order to warp with the amount of points I need and not keep clicking the wrong point!!
PLEASE!
drazkers
Re: Advanced Mapping Feature
Post by drazkers »
Until that happens you can use the keyboard to move over one pixel. Which is the smallest amount anyways. Hopefully that helps yah out.
you can resize the advanced output window to get a bigger work area.
zoom function is on the to do list as far as i know.
