Colapse Layer in GUI
kclarkmusic
Post by kclarkmusic »
In my new show file, I have many more layers. It would be great if you could collapse a layer that you don't need to view (similar to how effects in the effect chain can collapse)
Potential Situations:
- Logo Layers
- Capture Card input layers
- Dedicated show content (like produced video sequences)
This paired with "persist layers" would be great.
Could be a bug but I noticed that when copying clips that had Clip Transform data or Input sources to other decks, the clip settings would not be copied over, as if the clip was just brought into the show file.
