Resolume 6.1.3: The Enchanted Princess
The 6.1.3 update has enchantment galore. We worked on stability and ease of use, but above all, we used our magic powers to make Resolume more beautiful, more elegant and more enchanting. She now feels like the princess she deserves to be, and we're sure you will too.
Cinderella Decklink
Blackmagic devices are the princesses of video. So much so, that after dancing at the ball for more than 24 hours, the output would freeze and need to be reset. We now make sure that Cinderella doesn't turn into a pumpkin and is home in time to do her chores.
Out of the Dark (Into the Light)
Alley would start up with a completely black interface on laptops with both an integrated and dedicated GPU, unless you explicitly told it to use the dedicated GPU. Not a showstopper, but definitely annoying, so we now set the GPU for you.
Radial and Linear Cloner effects
These were two very popular plugins by Hive8 back in the Resolume 5 days and a lot of you were requesting 64 bit updates for Resolume 6. So we took their basic premise, very literally added our own twist and made them native Resolume effects. Thanks very much to Anton Hive8 for letting us use his idea and to STV in Motion for the moral support and preset making.
今日のVJブース
Just like the manual, the Resolume GUI and Help are now also available in Japanese. すごい!
Now go fit your glass slipper on that download or check the full fix list below.
10508 Possible crash crash resizing GUI
11066 Load capture sources with a sensible resolution
11334 Launching selected clips with Enter works only once
11970 Alley UI is black on some laptops
12021 WMV files rendered semi transparent in Alley
12054 Text animator Rotation is displayed as radians
12059 NDI output is black when composition is bypassed
12068 Crash when opening Avermedia cn311-h capture source
12083 Update to NDI 3.8
12109 28.77 FPS DXV2 file shows and plays as 6000FPS
12111 Avi with RAW UYVY codec plays in Alley with a wrong duration
12127 Text animator doesn't show whitespace at start of a line
12139 Fit/Fill/Stretch is not part of preset in Alley
12147 Shift RGB no worky when animated in Zoom mode
12153 Alley crashes when Startup Screen is visible and nudge shortcuts are used
12168 Radial and Linear Cloner effects
12186 Crash selecting audio input device, when the previous device had more channels
12251 Japanese GUI & Help Translation
12331 Transform Position Y Start Stop range doesn't follow composition size
12374 Decklink outputs freeze after 24 hours
12376 Crash in Advanced Screen setup doing undo-redo
trekfan42
Re: Resolume 6.1.3: The Enchanted Princess
Post by trekfan42 »
Thanks, I had mucked about a bit till i figured this out, but thanks for the fix!
OOOHhhh, thank you kindly!!!
haha this is why i love reading the patch notes.
Thanks for your hard work!
Cloner effects!!!! Thank you very much!!!
dadofranca
Post by dadofranca »
thanks :D
francoe
Post by francoe »
Ciao principessa, chiamaremo a mario.. o luigi.
francoe
Post by francoe »
Love it.
Tip for next release, include start/end opacity controls in linear cloner.
NO, I'm not talking about time delayed clones. :twisted:
Okay, we had time delayed clones ready, but if you don't want them, we'll take them out ;)
francoe
Post by francoe »
Haha Was a way of saying: I'm not asking for big changes, just little tune ups. All stuff is welcome, you mad hatter :mrgreen:
