Resolume 7.2.1 Maintenance Release
We're very happy to hear you all really like the new clip renderer and recording improvements that we released a couple of weeks ago in version 7.2. Today we're releasing version 7.2.1 that has redesigned dialog windows and fixes a bunch of bugs.
Fix List
#13737 Clip with ProRes 4444 + alpha reverts alpha type setting
#13739 This ProRes clip with alpha displays differently on mac and windows with premultiplied alpha
#14165 Playing h264 in random can crash
#13824 Position field on Clip playhead doesn't show selecting paused clip again
#13920 Scaling / sampling in the Advanced output lets pixels bleed
#14001 Slice transform in mask mode lags a lot after ASS changes
#14098 Long fixture names overlap a lot in Advanced output
#14005 Crash waking the machine from sleep with NDI clip loaded
#14184 renaming Fixture parameter to same name as another one, renaming it again changes different channel name
#14198 Crash clearing capture clips
#14346 7.2.0 can hang with advanced output open on windows
#14020 Moving group below itself, layer order can change in group
#14349 Can't move group below a layer below
#13478 Alpha channel support for HD-SDI outputs with BMD capture cards
#14354 Multiple inputs on AJA Kona 4 show glitchy
#14361 DataPath boards not loading
#14362 Popups & menus getting stuck sometimes
#14355 Alley, Crash trying to convert with an unsupported file in the list
#14378 Rendering a paused clip, the render gets the first clip frame instead the one at the paused position
Download
Select "Check for Updates.." in the Avenue or Arena menu and it will self-update. Or just checkout the downloads page.
