Checkout this new set of Max for Live patches that allow you to control Resolume from Ableton Live without requiring any tedious MIDI mapping. You can trigger clips and control parameters so once it's all set up all you have to do is concentrate on your music and effects in Live and Resolume will just follow.
Clip Launcher
This is a simple way to connect clips in Live to clips in Resolume. Simply drop it on a track in Live, and it will trigger clips in Resolume when you trigger clips in Live automatically. It corresponds exactly, so clip 1 in track 1 in Live connects to clip 1 in layer 1 in Resolume, clip 2 to clip 2 etc.
- ClipLauncher.png (14.58 KiB) Viewed 72244 times
Parameter Forwarder
Dropping this guy behind an effect in an effect chain, will allow you to forward parameter information to Resolume. You can choose which parameter you want to forward from a dropdown, and send it to any parameter in Resolume by entering the OSC address.
- ParameterForwarder.png (37.88 KiB) Viewed 72237 times
Resolume Dispatcher
The Dispatcher connects the Clip Launcher and Parameter Forwarder to Resolume. You always need to have an active Dispatcher in order to communicate between Live and Resolume (but you canʼt have more than one).
- Dispatcher.png (15.71 KiB) Viewed 72244 times
Download
Download v2.2, compatible with Resolume 6.
Download v2.3, compatible with Resolume 7.
Download v1.10, compatible with Resolume 5 and earlier.
Instructions PDF
Version 1.8 and up now also send BPM values and Start/Stop messages...
- Dispatcher 1_8.png (17.12 KiB) Viewed 64023 times
Thanks to Mattijs Kneppers from
Arttech.nl for creating these handy patches!
