@illy: you have to switch toggle on for that button in edit mode of the bcr....we've had the same problem
@m3co: ableton should send a midi clock signal, so just connect the 2 softwares right and try it....
there is a bug when using midi to tap the beat :Message original : illy
1. i have the bcr2000 controler, i tried to put the tap button into the controler. And when i tap, i get the value round 500 bpm. And i dont know how to change this. I tried to edit the button mode in the controller but it didnt fix the problem. Maybe some ideas? The resync button works well on the controler
Is there cheaper choise ????Originally posted by lichterloh
http://www.redsound.com/products/soundbitemicro
