Max for Live Resolume Patches
XstaticVisuals
Re: Running the AV show on just one MacBookPro
Post by XstaticVisuals » Thu Sep 01, 2011 15:19
This all sounds like serious awesomeness, but would one be able to run the AV show with Ableton controlling Resolume on just one MacBookPro.
That would be absolutley amazing.
Thanks for everyone's contributions to this thread.
leolodreamland
Re: Max for Live Resolume Patches
Post by leolodreamland » Thu Sep 01, 2011 23:46
shouldn't be a problem. i wouldn't run tons of vsti plugins in ableton. render it down to audio if possible. of course it depends on the spec of the mbpro. max out your ram.
____________________
chromatouch visuals
VM_Nexus
Post by VM_Nexus » Sun Sep 25, 2011 18:18
Can anyone tell me how to get the parameter forwarder to work with dummy midi clips? I have it set to watch a macro knob - if I turn the knob physically then it changes the parameter in both Live and Avenue. If I trigger the dummy clip then I can visually see the knob's position changing in Live (e.g. working normally as far as I can tell - the same way you'd do dummy clips for audio fx) but no signal is sent to Avenue.
oniromante
Post by oniromante » Tue Dec 06, 2011 12:54
This m4l paches are awesome,however i have experienced this BIG ISSUE Parameter Forwarder:
1)when i turn my knob in korg nanokontrol i send a cc midi order from 1 to 127,but in parameter forwader i can only get values o or 1.I have seen in the demo video the same values in both secctions of parameter values,and i can´t get that at all.I have tried korg kontrol editor without success.
In the midi secction i see 110 and in the osc section i see 0.7 for example
2)so i can´t get middles values for example in opacity slide in resolume,when i turn the knob i only see everything black or everything opaque.i can´t get proporcional ratio between midi and osc
thanks for the help and excuse my english
i love this tool y really need help
Post by Joris » Fri Dec 16, 2011 16:24
Hi Oniromante
1. OSC signals need to be a value between 0 and 1, where MIDI signals are usually in the range 0...127. So the parameter forwarder will do some math to 'translate' the values to something OSC can work with. So 110 on MIDI could well mean something like 0.7 on OSC (probably something closer to 0.85, but you get the idea).
2. This shouldn't be the case. If you send a mail to mail@resolume.com, describing your setup, we can see if we can solve your problem.
oniromante
Post by oniromante » Fri Dec 16, 2011 18:03
Hi goto 10
thanks for your help.I will send that mail because i am really mad about this tool.
My setup is one pc with ableton and another pc with resolume in local network.I use audiobox presonus driver on audio pc with korg nanokontrol and asio4all driver in visual pc with resolume.Soon i will try to do this in just one pc...i dont know if this issue could be because of the network.The other m4l patches for resolume works great in my setup.
thanks again
leolodreamland
Post by leolodreamland » Sat Dec 17, 2011 15:11
Mattijs wrote:Regarding bundles: it's not hard to modify the idiron patches to support this.
no but it is hard to modify touchosc to support it. please enable auto detection of bundles in resolume, once again!
chromatouch visuals
oniromante
Post by oniromante » Thu Dec 22, 2011 22:17
Finally i could solve my problem.i am a new osc user so i was making this mistake:when i copy the osc order from resolume,for example "/composite/video/effect1/param1/values f "to ableton parameter forward i copy the whole order and i was having trouble but is i copy only "/composite/video/effect1/param1/values" without "f" (from float i supose) is working right..so it was that...thanks a lot for reading and for the help.It is working really really fast,much better than midi rewire with midiyoke!!!Awesome!!!It is working also with m4l patch for midi clock through osc,so at last i could do some own visuals.
this is my first visual (without effects but just wait for the second!!!)
http://dbr3d.blogspot.com/2011/12/3d-monome.html
Borister
Post by Borister » Mon Aug 13, 2012 18:00
In the video there was a short hint of using the parameter forwarder to control the playhead. What do you think he was referring to that controls the playhead for the Ableton side? Is there any way to forward the Ableton playhead position to the playhead in Resolume? I know that the clip launcher does that, but if I set the cue point in Ableton, it does not translate to Resolume, even if I use the same exact mov file in both programs. Is there a way to 'lock' the playheads together via the parameter forwarder?
pbs99
Post by pbs99 » Mon Oct 01, 2012 15:46
these m4l patches are fantastic!!!
+1 on the playhead/clip linking. would love to do clip mashing linked to cue points in resolume.... how cool would that be!
i'm trying to figure out a way to link the crossfaders in ableton and resolume via OSC. Has anyone done this successfully via these patches(i'm using an APC40)?
