Max for Live Resolume Patches
TCO
Re: Max for Live Resolume Patches
Post by TCO » Sat Jun 15, 2013 13:24
Am not able to get this work properly. Am on Windows 7 64 bit, with Live 32 bit.
1.Have set the OSC port in Resolume to respond
2. Have all the devices properly set up in Ableton
3. Am starting Ableton first then Resolume
dubtrack
Post by dubtrack » Thu Jul 23, 2015 15:33
It is not working for me either. I'm on a Mac 10.10. Ableton Live 9.2. Resolume 4.21.
I can see that live 9 is transmitting into the trigger patch.
Any suggestions?
Regards
Ole
Post by Joris » Thu Jul 23, 2015 15:42
Because you're dealing with multiple applications, the best way to troubleshoot OSC problems is to use OSCTestApp ( Mac ) or OSCMonitor ( PC ) to see if the values are actually being sent and what those values are.
That way you know if Live is sending anything at all, what Live is actually sending, and if Resolume should react to this.
hønse
Post by hønse » Wed Nov 09, 2016 22:05
I'm using the "resolume clip launcher". However, as you can see in the video my clips doesn't trig at the same time. First layer 1 launches, then layer 3 and then layer 5. When I launch directly from Resolume there's no problem. Any idea about what's going on here? Thank you!!
p8guitar
Post by p8guitar » Fri Dec 08, 2017 20:23
Does it work with Resolume 6?
The parameter forwarder seems to work. But the dispatcher doesn't sync the tempo. Do I have to set something special in the Resolume preferences to get this working?
caseyprice321
Post by caseyprice321 » Thu Jan 11, 2018 02:08
Is the OSC message sent from Dispatcher or the Clip Launch? Where in the M4L program is the signal originating so I could modify it? It appears Resolume 6 may have altered OSC signals and broke the patch. Im a novice with OSC, so take my questions with a grain of salt. I opened OSCtestapp and the signal sent does not match Resolume 6's clip/column OSC strings. Any help on this would be awesome!
DHoude
Post by DHoude » Fri Jan 12, 2018 03:03
I may be wrong, but I think Ableton Link is what is used for tempo in Resolume 6.
http://www.facebook.com/DJHProductions
Win 10 pro 64 bit - b1809 - 2.7ghz i7, 16 gig, 3 SSD internal drives
NVIDIA 870m v 418.91
Resolume Arena 6.12 & Akai APC40 MKII
Virtual DJ 8 & NS7 III (video DJ)
Ableton Live 10
DHoude
Post by DHoude » Fri Jan 12, 2018 22:52
To quote Zoltan: "Ableton Link is not exactly timecode, but rather the beatmark position, so yeah, it won't trigger any clips, but it will allow you to sync up two or more machines to the beat, so you can launch beat snapped."
I think that might be your answer
Ableton Live 10
Denys
Post by Denys » Thu Jan 18, 2018 21:18
If you want to try this, I think is a good solution to control Resolume6 from Ableton Live.
I only continue de work that Mattjis kneepers did, with extra added things.
Here is a downloading link:
http://ooeevv.com/webwp/controlling-res ... c-v-1-6-1/
If you try, let me know. Give me your feedback.
Cheers.
glenben
Post by glenben » Tue Sep 25, 2018 09:37
Hey
i'm using clip launcher and am wondering if there is a way to trigger a specific clip. In live session view I'm on row 5 and want to start the first clip in resolume, right now, the only way i see is to put that clip on the 5th columne in resolume. Is there any other way?
thx
