DXV Alpha Channel
vjgalaxy
DXV Alpha Channel
Post by vjgalaxy »
Hi, hope you are well. We often create animations for VJs using After Effects. We're rendering DXV + Alpha Channel files from AE, but, we've tested the files into Resolume 4.1.8 (Demo), but it doesn't recognize the alpha channel.
Some ideas?
Thanks in advance.
Alejandro Piñero Amerio
Video Design | Media Production
https://vjgalaxy.com
vjgalaxy
Re: DXV Alpha Channel
Post by vjgalaxy »
I think I've figure out the solution. The video opacity must be set up at 0.50.
pfelberg
Post by pfelberg »
Nope. Resolume must and will recognize your alpha channel properly.
There´s no need for changing the opacity.
My guess is that you forgot something while exporting from AE. I´ve been there before ; )
For a full step by step guide on how to export from After Effects with the DXV codec, check here: https://resolume.com/manual/en/r4/dxv#a ... er_effects
Frischvergiftung
Post by Frischvergiftung »
Yeah you probably forgot either to tell the codec it to preserve alpha or didnt render rgb+alpha.
