multiple effects not working in one composition
Schaupau
Post by Schaupau »
Hi there,
i have some problems with some effects which will appear in one particular Composition.
When i drag & drop them to Composition-/Layers-/Video-effects
they will not appearing there. Note, that this is appearing in since yet, in only one comp. I have tested this in an New Comp and everything is function normal...
I am working on 4.1.8 since yesterday.
Before it was all fine with version 4.1.4. I have also expiriencing some problems with FRAPS and recording the output screen, but they disappeared...
Some ideas?
This is with following effects:
-delay rgb
-displace
-distortion
-displace
-FishEye^
-Heat
-Mirror (Mirror Quad is working)
-Particels
-Pixel high pass
-Posterize
-Recolour
-Ripples
-Slide
-Snow
-Solid Color
-Strobe
-Terrain
-Threshold
-Tint
-Tunnel
-Twisted
-Videowall
-Vignette
thx!
Schaupau
Re: multiple effects not working in one composition
If there was a significant problem with that many effects, the forum would be exploding with posts about it.
I think there may be an issue with your particular comp. If you want us to look into it further, perhaps you can contact us directly?
