mapping problems
Pxlsx
mapping problems
Post by Pxlsx »
I have a 4.1.8 Resolume arena with a seriously mapping problem, when I choose the advanced option, the display shows an error like a glitch background. it's weird because it never happened before.
I need you to help me.
I try with other versions but is the same thing.
MacBook Pro OS X 10.9.4
2,4 GHz Intel Core i5
4 GB 1333 MHz DDR3
yosoypedro
Re: mapping problems
Post by yosoypedro »
Any solutions? I think I may have experiment the same issue last weekend at a concert.
He2neg
Post by He2neg »
Did you check the status of your Grafik Card ? Maybe it allready burns ;)
I had some weired stff going on while the fan was broken after some time of running stuff.
~Berlin~
It sounds like you are using a graphic card that does not pack enough punch to run the Advanced Output.
What does the log report as the main OpenGL Renderer?
You can access the log by going into Resolume > Feedback > View Log and then scroll down to the part where it says 'Main OpenGL Renderer'
There's some screenshots on what to look for in this thread.
stereo-out
Post by stereo-out »
I HAVE BEEN EXPERIENCING THE SAME PROBLEM WITH MY MAC BOOK PRO AS WELL
MY CONFIG IS ALSO PRETTY GOOD BUT I STILL FACE THE SAME ISSUE
PLZZZZZZZZZZ HELP
The first thing is to make sure your caps lock is off.
Hey Stereo-Out, do you have a MBP with a discrete GPU or just the integrated GPU?
