R6 - Height ignored in Group
Kadete
Re: R6 - Height ignored in Group
Post by Kadete »
Joris wrote:Well, you know how I think about Layer Routers and that using the Advanced Output to do more than one mapping.
If you have a better approuch to obtain the same result I would love to ear.
Sure. I probably sound like a broken record at this point, but here we go.
:p Sorry about that, I will try your workflow (doesn't look much flexible without the mapper)
Btw, r6.0.6 broke my comp. If i click anywhere, it shows resolume stops responding. And the non Persistent clips and Decks are gone: (leaving now for a gig, i upload the comp later)
PS: Rollback to 6.0.5, weird now the Y on Group its working like i asked ... i'm going crazy :o
Lose some, win some :)
Send over that comp file and we'll see if we can't fix things for you.
Kadete
Post by Kadete »
Joris wrote:Lose some, win some :)
Resolume wangs when i try to exit (when the preview goes black in the video)
Tried to create or open other composition, also "clicks" being ignored. although i can open output mapping window.
I have send you a email with the composition. Have fun. :)
https://youtu.be/6k-VLlcSoy0
