How to trigger Resolume clips from Ableton Live
eeddddd
Post by eeddddd »
How do I trigger specific Resolume clips from Ableton Live.
Can I use Ableton Link to trigger clips in Resolume.
I'm running Resolume Arena 6.0.10 and Ableton Live 9.7.5 on a Mac Pro High Sierra.
I'm new to Ableton so any tips would be much appreciated.
Thanks in advance! :D
Dirk67
Re: How to trigger Resolume clips from Ableton Live
Post by Dirk67 »
I used an electronic drum set to trigger videos in Resolume. To do that I ran the MIDI signal through Ableton Live into Resolume. I followed these instructions. https://www.youtube.com/watch?v=2Xy-R6qwEGw
I would assume that you could create a Midi signal directly in Ableton. Hope this helps a bit. D!RK
eeddddd
Post by eeddddd »
Thanks Dirk76, this looks great, will give it a try.
Have you ever used Abelton Link to trigger a specific clip in Resolume?
Dirk67
Post by Dirk67 »
No, have not done that. I don't really use Ableton at all but it worked well as a bridge between drums and Resolume Arena.
eeddddd
Post by eeddddd »
Oh cool. Thanks for the help :D
