Hi , i use the recolour effect a lot but it always recolours my alpha channel too, is this normal behaviour or could it be fixed in a update ?
I would expect that if i toggle off the alpha channel in the fx router (when using recolour as a clip) , it wouldn't affect the alpha channel but it does.
Because of this i got to use .png masks on the layer/group so the recolour only affects my image and not the entire clip dimensions.
It often means i have to add another layer in mask mode to make a 'live video mask' of the layers below just to cover off the rest of the effect.
Is this fixable please ? Any other workarounds ?
