hi there
can anyone help me?
im relatively new to using resolume, and have a gig 2moro.
what process and output resolutions should i set in the dual monitor screen setup?
approx 15m throw distance from projector to screen. dont know specs on projector but somewhere from 800x600 to 1024x768. 5m screen size. front projection in dark room.
all my clips are to cinepak avi specs, and im making 2 batches to trial - 640x480 and 400x300. im a resolution freak so even these resolutions hurt to use!
so i was going to set process resolution to the resolution of clips themselves, and output res. to match projector. however a friend told me to set both to 800x600 and use resolume to do the scaling. apart from trial and error, what do u think?
using v.2.3 with toshiba satellite M40. 2Ghz pentium M, 1 gig RAM, nvidia geforce go6600 graphics card with 128mb RAM. all decks will be filled with clips. wont be using effects generators much.
thanks!!!
