Need normal countdown Plugin
Hey Guys,
can someone point me to a Resolume FX/Source.
I just need a simple countdown where I can set the time manually.
I already pruchased "Countdown" via Juicebar....but there you are only able to set a date and time for the Countdown to end. Its a nice feature....but not ideal for me.
I just want to set the time to for example 15 minutes.....or 45 minutes. An "Go" for countdown.
Anyone?....I am a bit in a hurry (-:
love you
Empyfree
Re: Need normal countdown Plugin
Post by Empyfree »
I know this isn’t what you asked for but...
Could you find a suitable 60 minute countdown video (there are dozens fairly easy to find) and then just start it from where you need?
Yes this would also work .... But for now.. I am too lazy to create one by myself, because I have to use a CI Font for the countdown. ;)
Oh man... "Counter" from Juicebar is almost perfect....except from this missing feature. damn :)
Might as well join the team
I just built this little guy for you, Hopefully this will work. I'll get around to making a tutorial video for it later this week, but i'm sure you can figure it out (there's a small help section when you click the ? and then click on anything orange).
It outputs OSC strings to Resolume's text blocks that you can then change the font, color, size and positioning of. Just copy and paste OSC from Resolume to Count Down.
It also sends out Spout and NDI if you just need something quick.
I also built in OSC and DMX triggers for 10 seconds and 0 seconds so you can fire off light desk cue stacks or fire off a video or something inside Resolume when you get to those special moments.
Try the DEMO out first, it's 5 min long, so set your timer or Time Of Day countdown for 2-3 min for testing, if you like it, it's $5, which is typically $20 cheap than the other plugins out there.
Hope this will get you buy for now? :)
https://gumroad.com/l/count_down_demo_pixel_party
Hey Arvol,
Sounds great! Thanks..... I will give it a shot after the rehersal day today.
I'll let you know if it fits the needs.
greetings
Hey Again....
your download links on your page are not working.
greetings
Seems to be working for me this morning. Not sure what's going on, you might give it another shot
