I can't start clips simultaneously
dim_2007
Post by dim_2007 »
actually, I found this post
viewtopic.php?t=16714
but whatever I do only one clip start
so I still can't start two clips simultaneously
2. and my experiments with Clip Trigger make my Resolume works like crazy (clips load to the different layer, not to the layer where it is. At some layers it's not possible to load any clip. Clip from layer 13 goes to layer 10 but Clip from layer 15 goes to layer 14. I don't understand what's going on...
is there any Reset button to reset all my trigger movements?
3. Now I switch on Layer Transport Control and see there are some layers with Transport although I didn't set any of them... I don't know how it has happened...
Might as well join the team
Re: I can't start clips simultaneously
If you have specific clips that need to trigger together and are separate from other clips that don't need to be, you can put those 2 layers into a group and then use column trigger in that group to fire off those clips.
