Save all settings and compositions in a folder
LJ2F
Post by LJ2F »
Hi everyone !
I'm trying to save my project, preset, comp and so on.
I've created a folder in my local drive My PC > Local drive (D:) > "Resolume folder"
Then, I go to Arena > Preferences > General > Record Directory > Browse "Resolume folder"
Next, I save my composition (save as) and I save my interface presentation (view > layout > save).
But, nothing got saved in my folder. My project .avc and my interface .xml have been saved in My PC > Local drive (D:) > Documents > Resolume Arena 6 ...
What I am doing wrong ??? Is there a hidden setting ???
Thanks a lot !
Might as well join the team
Re: Save all settings and compositions in a folder
https://resolume.com/support/en/media-m ... lect-media
For things like advanced output and shortcuts, you will need to transfer those manually.
LJ2F
Post by LJ2F »
Hi Arvol, thank you for your answer.
So, by default, Resolume creates, saves and writes its owns files in the "documents" folder.
And there’s no way to change this location. If I want to use my settings on another computer, I just have to copy and paste my files into this new "document" folder too.
So, my settings will automaticaly appear when the software will be opened on this new computer ?
Thanks again for the help
Correct, If you just copy the entire following folder:
C:\Users\*Your Username Here*\Documents\Resolume Arena
And paste that folder into the new computers documents folder, and then do the media manager export in the link from my last post, that will get you a 1:1 copy on the other computer.
LJ2F
Post by LJ2F »
Ok I've understood, thank you
