RGB delay slider turned to one side changes closes clip...?
vj8k3
Post by vj8k3 »
not sure why this happens
but when i turn a effect (noticed it on rgb) all the way to one side it closes the clip
made a small video of it here:
https://www.youtube.com/watch?v=79NkvWOUoD4
๐Ÿ‘ฎโ™Ÿ ลŸ๐•„๐•†โ“šแ—ด โ„‚ัโ“โ„ƒ๏ฝ‹ ๅ„๏ผกฮนฤน ๐“ˆฮ”โ“‰๐’ถล‡ ๐Ÿ˜ŽโœŒ
Asus pro duo
Intell cor I7
16 gig ram
Gforce rtx 2060
mouse
Might as well join the team
Re: RGB delay slider turned to one side changes closes clip...?
Try a new MIDI mapping file from scratch. It looks like you mapped a value to fire a clip, when you turn it all the way it launches an empty clip to the far right. I bet if you use a new mapping file and then re-map it, it won't happen ;)
