External FFT in stereo
Evelina
Post by Evelina »
I use External FFT for animating effects and want to difference between FFT input 1 and 2. To clarify; I want left audio input to animate an effect in layer 1 and right to animate an effect in layer two, for example. Can't find the pan knob :roll: Have I missed something or do I have to search for a workaround?
Re: External FFT in stereo
Only one external FFT input is available currently.
If you select a stereo source, the channels will be merged to mono, and used that way.
booshtukka
Post by booshtukka »
I would love multiple external FFT inputs :)
