No monitor output
Ole
No monitor output
Post by Ole »
Hi
Just downloaded, but no monitor output.
Graphics NVIDIA Geforce 8800GT and latest NVIDIA drivers (omega driver were from 2007 so I skipped that....)
Any suggestions ?
Basic
Re: No monitor output
Post by Basic »
does the application load ok?
whats your setup?
a bit more info please :)
Most likely this can be fixed by installing the latest nvidia drivers or by setting the drivers to "Compatibility performance mode".
"Open NVIDIA control panel and go to 3D Settings->Manage 3D settings. Then on the Global settings tab change the 'Multi-display/mixed-GPU acceleration' setting to 'Compatibility performance mode' and choose apply"
Hope that helps.
Ole
Post by Ole »
Hi !
I've already done that, doesnt help though. The PC is Core Duo 2,66 Ghz and graphics board is 8800 GT so enogh power should be available. Have also uninstalled and reinstalled.
Any suggestions ? (I WILL buy this program as soon as it works for me....! )
Ole
Post by Ole »
Latest drivers installed also, windows only show up white ????????
Please send us your logfile by using the Feedback option in the Preferences.
Thanks,
Ole
Post by Ole »
OK what log to return ?, I'm in event viewer but there is so much there I dont know where to find and export what you need.
When you go to the Feedback tab in the Preferences of Resolume, there is a checkbox for including the custom logfile Resolume creates on your computer. Make sure you tick the box to include it. Also, please include any info you feel could be relevant.
Ole
Post by Ole »
Hi
I've returned the logfile, latest Nidia drivers are installed and settings set to compability mode as suggested by Resolume and others. Stll no output !
What to try now ? I want this program !
Ole
damstraversaz
Post by damstraversaz »
Hi
I'm actual y trying resolume too,. all works perfectly on my win7 64 bits system, but I have the same problem with my other laptop ( win xp 32 bits, nvidia card, I try too the compatibility mode tip) The preview monitor works perfectly, so I suppose codec are fine. Ijust try with the demo project ( avi cinepack, installed on my computer). there is on the output monitor the "resolume logo appears on the output monitor, but no video.
I will send to you the log file
All the best
damien
digital arts:
http://www.damientraversaz.com/#!art-numerique/c1s43
music for dance, documentary and digital arts:
