Palette - fingerpainting in Resolume 7 with the Sensel Morph
nosuchtim
Post by nosuchtim »
I've developed an FFGL plugin for Resolume 7 that allows you to fingerpaint visuals using the Sensel Morph.
If you have a Morph and are running on Windows, you can give it a try. It includes a separate GUI that allows you to select and edit visual presets. You can loop your finger gestures. It's essentially a stripped-down and reworked version of the software I've been using in the Space Palette for years (hence the 4.07 version number). Visuals only, no music, although the music generation is in there and may be exposed eventually.
Installer: https://github.com/vizicist/palette/blo ... _setup.exe
Documentation: https://github.com/vizicist/palette/blo ... esolume.md
Questions and Suggestions: me@timthompson.com
...Tim...
