Thank you so much! Do you know if this has support for hardware such as the blackmagic ultrastudios? In ProPresenter we can use the "A" SDI output as Fill and "B" SDI as Key on the ultrastudio units.Empyfree wrote:Yep. In advanced output create two slices from the same area. Assign one to each of two sdi outputs. On one tick the "is key" option and voila.
This would work but you can not select the output data for each SDI post as the US4K device is seen as one deck, not one deck with 2 outputs. I wrote about it here, to give an explanation of the situation.-TRFN- wrote: ↑Wed Aug 23, 2017 21:29Thank you so much! Do you know if this has support for hardware such as the blackmagic ultrastudios? In ProPresenter we can use the "A" SDI output as Fill and "B" SDI as Key on the ultrastudio units.Empyfree wrote:Yep. In advanced output create two slices from the same area. Assign one to each of two sdi outputs. On one tick the "is key" option and voila.
