shortcuts in resolume
jakub_
Post by jakub_ »
Hi there,
is there any possibility to assign effect on individual loops in Resolume by shortcuts? Current shortcuts allows me to do it only globally...
thx
m_
Post by m_ »
yes..
click and drag the effectgenerator into the individual channel, or use the ctrl+shortcut and the effect will be applied only on the channel that is highlited..
jakub_
Post by jakub_ »
huh... cool, thank you :) i tried it with shift :))
er... one more question - i can controll only few effect with this... so - is there also any chance to customize shortcuts for all other effects? I dont like dragging them on channels, scrolling with tab, switching between generator and browser...
edwin
Post by edwin »
by doubleclicking an effect in the generators tab you can set it's properties. You can assign an keyboard and midi shortcut to each effect. But this should be all in the manual, and this online as well as on your computer...
cheers
