Countdown source
DHoude
Countdown source
Post by DHoude »
With the removal of Flash in Resolume 6, I am in search of a countdown solution. I know Linear OSC is great for launching. That is not what I am looking for.
I am essentially looking for a text generative source just like the Resolume 6 built in ones. Something I can adjust font size and location on screen and the background supports transparency. I would like to set a target date/time and have it countdown to that time based off of my system clock. Just something that can show the status of a night live on screen.
Does FFGL have this capability? NDI source? Other options i may not have considered? Just seems like such an important and requested tool to still not have a solution yet.
I will probably use Linear OSC to progress through the clips in a layer. So this countdown source will be one clip. Then some customs clips that I will make will get launched for the final Countdown (no pun intended).
Any help is greatly appreciated. Thanks!
DHoude
Re: Countdown source
Post by DHoude »
I also forgot to mention that there does not seem to be a Shader Toy either.
Take a look at this post of mine from last NYE as it may be helpful.
You could create your own countdown in Processing, and syphon/spout it to Resolume.
Or just send the updated countdown text via OSC to a built in text generator every second.
DHoude
Post by DHoude »
The TouchDesigner projects works pretty well, Thank you. Exactly what I was looking for. I also had a client asking if I have TouchDesigner experience. At least this takes the pressure off and gives me a good example.
I don't have any programming experience, with minimal to no Processing experience. I have plenty of time so I will look at that option too. That is also why I was wondering if it was possible to make an FFGL source that does this.
OSC is still pretty new to me too. I am still trying to troubleshoot why the Linear OSC will not connect to my Resolume. I have done all the recommended settings in Resolume and even taken down the Windows Firewall completely. Just running the loopback 127.0.0.1.
