Hi I’m trying to fix an issue with ndi in resolume, could you please help?
The issue is that Resolume keeps occasionally blacking out the image of my NDI streams. It will work perfectly fine for a short while, and then the screen will go black, usually for a couple seconds at a time. It will turn black every few seconds or a few times a minute. The list of ndi sources also keeps changing in the sources section of Resolume, as if it keeps losing connection to the ndi source. The icon for the clip will also say OFFLINE in red outline and the clip will go grey in resolume. I don’t understand why it would lose connection though… the NDI stream is just a screen capture from the same PC.
Not all ndi sources seem to be having this issue in resolume. I tried feeding another ndi source from the mac to resolume on the pc and there are no blackouts. I’m not completely sure of all the sources it happens or doesn’t happen with, but i know that I keep having issues with NDI sources that are screen capturing the full screen of my computer monitors (called Desktop-JI9VE6N ( GeForce GTX 1080ti 1... and 2).
I think that this issue is specifically with Resolume Avenue because NDI seems to be working with every other app. I tried routing the same NDI sources into the NDI Studio monitor and there are no problems with black outs at all. I also tried routing the same NDI source into OBS via the NDI obs plugin and it worked perfectly. I tried viewing the NDI stream from both Resolume, OBS, and the NDI studio monitor all at the same time and found that Resolume would black out while the others worked fine. I also tried routing the same source into a Mac and found that it worked perfectly fine the the NDI video monitor app on mac, but I had the same exact problem with Resolume on the mac. I’ve tried restarting all apps, restarting the computer, and checking for updates in resolume and PC, but haven’t been able to stop the blackouts.
What is happening? Is something wrong with NDI in Resolume? What can I do to try to fix to make it work without blacking out?
