Hi
I work in small club and one guy has to operate the lights and the visuals.
So I'm looking for options to automize the visuals as much as possible.
First of all we're using Resolume 5.
I already use Artnet DMX input for controlling some properties/clips from the lighting program.
I think that next step should be auto-syncing BPM with the live music. I can use rec out from the DJ mixer (Pioneer DJM-900NXS2) and input it to computer as line in.
I wanted to buy Akai APC40 mk2, but then I saw a comment that it doesn't send MIDI clock.
How should I proceed to achieve auto-syncing? Which MIDI device you recommend?
