Dont know if anyone has talked about this here on the forum, i ran into these FFGL plug-ins for Resolume Avenue 3 made by
http://irworkshop.com
This is a simple automation of the clip's position in the timeline through a step sequencer, which is made as FFGL plug-ins for Resolume Avenue 3. IR ClipSA allows You to automatic change current clips like a ChaosMode in Resolume 2.xx. IR ClipSA Contains of four modules differ in the number of steps
and the the new one : FreeFrameGL plug-in - IR OSC StepAutomation
Is analogue of IRFaderSA only now it is possible to enter any OSC a command.
OSC commands sends on localhost:7000 in bundle mode.
In Resolume Avenue works only since version 3.3.0.
all this stuff is great, pc and mac .............and freeware
there is also a nice IR Cosmic PackFFGL plug-in effect pack for sale....check it out
