Rince is right about decrypting my message. I ment, file browsing tabs. Of course I do disagree on his statement he would loose space, and it opens a window for extra features that the freestyle veejay would love.
File browser1 | File browser2 | File browser3 (At the bottom, 3 tabs next to each other, insteads of 1 at the top,should take to much cpu power, perhaps some ram to store video-pool tree
You could also add speed jumps to those file browser tabs (RMB). So you can make favorites of your directories with shortcut commands. (Perhaps you should set a video-pool directory in your prefs, but this could also be the step to relative paths for the decks in xml
I find the features of the filebrowser somewhat lacking usuability and speed. But that's probably because I don't use prepared decks. (DO! use the tabs though)
Earlier mentioned on this forum are V-iD (Video iD, I/O points, playspeed, loop/bounce, perhaps even genre) tags which could perhaps be intergrated in xml format. Would also be a nice feature for the file browser, so you can narrow your vid pool by Video id data. jumping genres(or costum field) would be an awesome feature.
Ah well I will stop brainweaving
You see multiple file browsers a lot in explorer like apps, and I love it!
Give it some thought Edwin.
Cheerz.
nz
Sense
[Edited on 30-12-2004 by Sense]
