bpm synchronization
stanleystark
bpm synchronization
Post by stanleystark »
midi clock sync. it would be grea if resolume could go to the rythm of a midi clock... that means...to change the speed of the clips based on bpm values from the tempo using for each clip a base bmp (bmp on the original clip). This would require some type of metadata for the clips so that resolume knows what is the original bpm. Another thing is to have a kind of bpm counter with a number display and a beat indicator on a corner for tap control when not synced to midi, or to override it with plus and minus signs for tempo modifications and adjustments. like a dj pitch control.
[Edited on 19-2-2005 by stanleystark]
VJair
Post by VJair »
I got round th midi clock situation by triggering Resolume with a hardware sequencer with the midi clock timing generated by a Red Sound Voyager II,its a great combo;)
This way,you can make trigger patterns for videos and fx and sync them to the dj:)
stanleystark
what sequencer do you use?
Anonymous
Post by Anonymous »
:mad:
