Not sure if this is a good idea or not.
You could have a new type of cue point for a clip. The playhead could trigger this new cue point. This could be a checkbox or button that can't be clicked but only turned on via the playhead. Then, all normal midi / osc mapping could be done onto the trigger point's button. This would let you send osc/midi at a certain point in a clip.
If you can make a midi/osc mapping, you should be able to send dmx: so you could enable dmx mapping to output dmx to a Lumiverse to trigger a lighting console.
You could then also use this new trigger point with a virtual midi loopback interface to trigger anything else in resolume based off a position the playhead in a clip.
You could even use a trigger point to trigger a cue point to create a loop on the same clip - not sure the use case for that though.
