This is hands down my favorite piece of software these days, and its a wonderful tool.
However, here is a list of items that would be extremely handy!
1.) Multi-Channel Audio routing for surround sound setups. This would be extremely powerful when connected with Ableton Live, or to a digital mixing console.
2.) Drawable automation fades for audio and video that would allow for dynamic control of attributes within a clip. I.e. volume, opacity, effects etc...)
3.) Fades/transition between clips that don't influence an entire layer. Would be great if you could fade/transition between a specific set of clips within a layer without having to set the transition for the entire layer.
4.) GO BUTTON. Midi mappable advance column forward and backward buttons.
5.) Improved column, clip, and fader labeling/organization systems. It would be great to be able to label a column. Solid colors should match the actual color they are, rather than defaulting to red. Would be great if all faders (i.e layer A, AV, V) had visible numeric values for more precise mixing/cuing.
6.) Midi mapping list so one can find midi conflicts within programming/debugging.
7.) Trigger delays which allow for precise syncing of clips of varying durations.
8.) UNDO Button for clip deletion.
9.) Copy Clip Attributes/ Paste clip attributes. (similar to paste attributes in Final Cut Pro) This would copy all transform information, all effects information, and all transport information and make it paste-able to any clip(s).
10.) Decibel meter for audio.
11.) Composition Master pause/play fast forward and rewind controls that controls all currently playing media. This would be very helpful in a rehearsal setting.
Thanks for making an amazing program. I look forward to seeing what comes next!
