Collapse or hide layers and reduce groups
Bastian Kuenstner
Post by Bastian Kuenstner »
Hey there,
it would be nifty to collapse or hide layers that you don't use in a certain performance.
furthermore it would be very handy to reduce a layer group to only one layer so that all the layers in the group disappear and you only see the group master. with those features you could keep the GUI nice and tight without distracting things.
thanks in advance.
basti
OnniMation
Re: Collapse or hide layers and reduce groups
Post by OnniMation »
oooh yes! with big setups it gets a real hussle to handle the layers. I`m missing this function since the stuff with the mapping started. Dear brilliant coders from resolume, I bet this one is an easy one, isn`t it? it would help bigtime! :D
juicewon
Post by juicewon »
+1
5950x 3090 FE 128gb DDR4 2tb NVME X3
M1 Max MacBook Pro 64gb 2tb NVME
RazerBlade 16 4080 32gb DDR5 4tb NVME
