Relative mode for Clip effects/settings:
I never use layer transition duration but use opacity timeline from 0/100 to 100/0 for clips and if a clip have a timeline effect(scale) with bounce i can't repeat previous clip settings with active effect to normal hide him for 10 secs.
Envelope for Speed:
This will be great for bounce mode.
Autopilot for Column:
If i have 3 layers with 3 clips in 1 column and i set for them all autopilot in 5 secs to play next clips i will have active previous column and after i can't use Shift+Arrows but should use mouse to switch next column
