Allow animation for Clip's Transport Position
hepi.yellow
Post by hepi.yellow »
The Issue
Linear-time loops are boring... 🥱
We can't add beat syncing with meaningful envelopes that can bring life and groove to video clips.
Currently a clip's transport position can not have animation.
The Solution
Add support for animating transport position.
The current BAD solution
I know you would say: "Hey but you can map the transport position to Midi/OSC", but that is not good enough.
- It requires an external app to drive the parameter animation.
- It is probably not frame-sync-perfect like if it is running inside the Arena's render loop.
Conclusion
Seems like a quick win 👍
Might as well join the team
Re: Allow animation for Clip's Transport Position
When your clip is in BPM drive mode, Have you played with all the different Random settings for the Random play mode? This might be what you're after?
hepi.yellow
No. I am looking for more elegant curves, like exponential in-out is very good to bring some on beat oooomph!
