Resolume 5 to Sunlite
Kadete
Post by Kadete »
Hey everyone,
I never worked with DMX Output or ArtNet, and i'm felling a little lost of what it must be done to send information from resolume(laptop) to sunlite(PC).
Goal: launch scenes/buttons made on sunlite.
Should be bought any piece of hardware? Is possible just connecting directly via ethernet cable?
Couldn't found a pratical tutorial on the matter.
Any input is appreciated
drazkers
Re: Resolume 5 to Sunlite
Post by drazkers »
Do you know if sunlight can launch presets from a dmx command?
I've never used it, but that's a critical question for a Sunlite forum before you go down this rabbit hole. If Sunlite can launch presets via artnet it shouldn't be too difficult.
