Video and audio question
Miliya
Re: Video and audio question
Post by Miliya »
I'm trying to run 1920*1080 6 displays
One display running with 4 slides
All running with 48mb graphic content
Prossesor is core i7 7700 ,ram 32 gb ,grapic card Amd Radeon wx 9100
But when we cueing content. Are lagging not running soomuthly
I wants to know what is the issue all graphics outs are getting from. Wx9100 card
Might as well join the team
is your content dxv3?
Online
- What kind of SSD are you using?
- System Power profile to max performance?
- And of course.. are you using DXV like Arvol asked before.
Best wishes
Miliya
Storage and codex
Post by Miliya »
We using sata ssd to store content
And we using MP4 as content
Online
So then try to convert everything to DXV first, and try again.
Best wishes
Miliya
Out put lagging
Post by Miliya »
We've already tried out converting to dxv and other codecs.
Is there any other possible causes of this issue?
Online
How fast is your SSD? Can you give us the specs.... and how many videos are playing at ones when you "cueing content"
Best wishes
Miliya
Post by Miliya »
First I used m2 ssd it's also contain windows .so I installed new sata ssd for contents. When I cueing total 8 vedios are playing and all 1080 and 4 of them are playing in same display as slides
Ssd read speed 500mb/s
Online
Did you tried the following combination?:
dxv codec files on nvme?
Best wishes
