BlackMagic Ultra Studio Mini Capture
skulpture
Re: BlackMagic Ultra Studio Mini Capture
Post by skulpture »
cvanhoose wrote:The mini works as well, I have tested them all. Output is not functioning at this time.
So the Mini Recorder works but the Monitor doesn't?
cvanhoose
Post by cvanhoose »
well...... I have tried them all minus the miniMonitor. Do you need sDi out from the computer?
I am running 10.8.2 mbpRetina 2.7i7 Nvidia 650m ........btw
Arena 4.1.2
skulpture
Post by skulpture »
I don't actually need the monitor/sdi output, I was more interested in the recorder. But I was interested to see if you got the output/monitor version working out of curiosity.
NLS6XX
Post by NLS6XX »
Hey CVH, have you been able to test the Mini Recorder with an HD-SDI signal? I'm reading all kind of complaints on the BMD forum that people don't get it to work with HDMI & HD-SDI sources.
cvanhoose
Post by cvanhoose »
Yes, I have tried the majority of the blackmagic capture products, all capture methods working fine(hdmi/sdi/comp). output is not working. Everyone is having issues with them because they are expecting a plug and play remedy. The capture settings have to be precise with the device(s) you are outputting.
xniala
Post by xniala »
Hello,
for a video installation, I'm planning to buy a Mac Mini Thunderbolt (refurbished 2011 and 0S 10.7), a Sony HDR-CX410 and a BlackMagic UltraStudio Mini Recorder.
I want to record both audio and video streams via HDMI in 1080i50 (or 1080p25).
What I read here and on other forums about HDMI capture issues makes me anxious.
Do you think my workflow could work without issues ?
Alain
tannerlthompson
Post by tannerlthompson »
So would this work:
BlackMagic DVI Extender (SDI output) to Ultra Studio Mini capture
With the goal of taking the screen from one computer and input that into Resolume?
I have been battling this problem for weeks and this seems to make the most sense...
kmifflin
Post by kmifflin »
I have an ultra studio express, at 1080i 29.97 sdi i can get a 2 fps delay, however there is a strange refresh problem when panning quickly. I don't see this inside of the BM software, so I suspect it must have to with the opengl layer that resolume uses.
