Random Playback Freeze
Re: Random Playback Freeze
Thanks for the steps, I still can't recreate this using the example AV footage.
It's worth a shot to see if the audio codec is messing things up.
You can remove the audio track of a file by clicking on the X next to the audio info in the clip area: https://resolume.com/manual/en/r4/clips ... properties
syn
Post by syn »
Ironically I used that method to remove the audio over a clip that was annoying me during testing earlier today (I rarely have audio hooked up during performance, at least, not with resolume) but it hadn't occurred to me to try it on that clip.
I tried it and it seems to fix the problem completely!
Is it likely to be an encoding issue then? It doesn't look like a very exotic codec to be honest.
Clip Properties
Clip Properties
edit: I just checked to example footage and the only difference in audio (other than the fact that it's two separate files) is that T3_B.wav is 44100 Hz instead of 48000 Hz.
I didn't get any freezes with the example footage by the way.
