6.0.2 update doesn't start
theLABVisuals
Re: 6.0.2 update doesn't start
Post by theLABVisuals »
bart wrote:This issue is now fixed, new installers for 6.0.2 for mac are uploaded. If you ran into this issue please download again.
\o/ Thanking you!
msimon
Post by msimon »
Hey thanks for this Workaround.
It helped me after the High Sierra Update to 10.13.2.
It crashed my 6.0.1 Version and the Update to 6.0.2 didn´t help.
So I tried it and everything worked as expected
Thanks, so the quick solution I can give you and works on my machine is to
remove the Arena.app from your apps folder first,
install 6.0.1 no footage installer,
then install the 6.0.2 no footage installer, without removing the Arena.app.
Let me know if this works for you!
pette
Post by pette »
I try the update from 6.0.1 to 6.0.2 but when it restart R6 it crash.
I try to restart many times but it crash. now i try to install from zero.
I download the 6.0.2 version from web and I try to install
I saved the crash log
pette
Post by pette »
after update it doesn't start anyway.
thanks
pette wrote:I saved the crash log
Could you also send us that crash log please?
pette
Post by pette »
emailed to mail@resolume.com
