Doesn't make much sense to compare these, does it?gradek wrote:SSD- Crossair P128 internal SSD with OS and apps installed.
External - Western Digital Mybook 500GB (7200) connected via Firewire400
Anyway thanks for the testing.
What sort of foottage is it you are testing framerate with?sikanda wrote:@ gradek:
the strange thing is that if i run the same files over the internal drive which has about 24 mb/S read speed i achieve the same frame rate.
anybody knows the reason?
What do you mean? Is it too small for installing the drive inside the computer case? If that's what you are saying there are cages to install them in regular 3,5" slots. If you are talking about the size in GB you can simply forget what I'm writing heresikanda wrote:@ gradek:
the ssd is to small for internal so i would love to find a external connection.
rebeloverlay wrote:This is a fresh osx 10.4.11 install on macbook pro with aty radeon x1600
Could this be the problem?HerrNieDa wrote:yes... the X1600 is not a really fast one for higher resolutions!
with my ati 4870 everything seems endless
Avenue is designed to use the GPU of your graphics card for all the computation needed for displaying the image. This allows more room for other computation (updating interface, BPM, receiving data, audio effects etc) on the CPU. Overall, this should make the application run as efficient as possible for what it's meant to do.someone please explain to me why now quicktime can handle this a breeze and vj software can't.
