Hey Black_sire the Mapio 1.1b for Mac keeps s=crashing my computer, whats up with that? it works good on my PC..
I have it loaded and registered, then when i go to add the IRmapio effect tot he composition resolume closes.
IR Mapio 1.2 released
- Stickygreen
black_sire
Re: IR Mapio 1.0 released
IR Mapio 1.2 beta2 - crash fixed + MAC OS version
MAC OS X - http://irworkshop.com/dl/IRMapio_v1.2_beta2.dmg
Windows - http://irworkshop.com/dl/IRMapio_v1.2_beta2.msi
to Stickygreen: Try the new beta, crash may be gone off.
irworkshop.com
Regarding my past issue with IR Mapio EDITOR window crashing when maximized:black_sire wrote:IR Mapio 1.2 beta2 - crash fixed
viewtopic.php?f=5&t=7701&start=10#p31118
YES ! Fixed ! BraVo !
Thanx,
Julie
2013 - Present: Dell Inspiron 7720 laptop, Win 7 sp1, Nividia GeForce GT 650M
2008 - 2012: Dell Vostro 1700 laptop, Win XP sp3, Nividia GeForce 8600M GT
2004 - 2008: Mini PC ITX...
Official Website: http://www.juliemeitz.com
black_sire
Re: IR Mapio 1.2 released
IR Mapio download - Windows - Mac OS X
Changes in version 1.2
New effects
About support of VDMX5 (beta8) – I have fixed bugs in the demo mode on VDMX5beta, but the overall testing is still in progress. I would be glad if you try Mapio on the latest version of VDMX5 and report bugs. So, support of VDMX b8 is now in beta status. I would like to thank the VDMX5 team for support and for implementation of the functionality for Mapio.
New price is 149 Euros (not including VAT for Eurozone)
(for 2 and more licenses for 125 EUR per unit)
Academic license with a 50% discount is also available, please contact me
New effects
- Edge blending - Tip: The Auto input overlapping mode allows you to place input areas edge-to-edge without overlapping. Make sure that blending areas (marked by red rectangles) do not go beyond the working zone; otherwise you will get black bars in the output.
- Density of grid – This is the editor of vertical or horizontal frequency of nodes in the grid. Tip – Use the CTRL key to enable the drawing mode and to change the value in the current block with the mouse wheel.
- Curvature of edges by Bezier curves - look at the picture, everything is just simple.
- Masks – Now it is possible to move the entire mask as a whole, as well as a facet separately. Also you can insert a new vertex by double-clicking a facet. These improvements are related only to polygon masks. Manipulations with ellipse masks remain unchanged.
- Lock areas from accidental changes. hotkey "L".
- Switch between areas quickly using hotkeys "1-9", "0".
- Solo Edit mode lets you disable snapping of nodes and area facets.
- Resize the current area relative to the center by clicking PageUp / PageDown.
- New option to show vertical and horizontal guide lines which divide the working zone to 2 and/or 3 parts.
- Added the snap-in effect to the corners of the working zone and to the guide lines.
- New About dialog in which you can activate the License key, see the version and other information. A separate application called "Mapio Activation" has been removed.
- Switch between areas (select the current area) by double-clicking, earlier it was possible on a single mouse click.
- Now zoom can be less than 100%. Also a new option called "Allow to drag outside" is added to Settings. It allows you to move area nodes outside the working zone.
- Now, the geometry of the input area is described by 4 points, so more configurations are possible, not only rectangular ones. To allow the input of nonrectangular areas, put a tick into the checkbox in the settings for the “Allow nonrectangular input” item.
- “My documents” is set as the initial folder for the "load \ save to" functions.
- New options in Mapio FX - enable \ disable the cursor and "Only output" - to disable automatic switching of display modes (input \ output).
irworkshop.com
YOU ARE THE BEST!
THANK YOU SO MUCH!
"Without order nothing exists, without chaos nothing evolves"
I updated to avenue 3.3.2 and IR 1.2.1 and now video won't show on the output. All it shows it the grid. Is there a new setting i'm missing? Video shows up fine when input mode is selected. For some reason the video of the layer isn't being applied to the output.
- Attachments
- Mapio editor closed
- editing closed.jpg (222.07 KiB) Viewed 22446 times
- Only Grid on output
- output.jpg (183.58 KiB) Viewed 22446 times
- Video works with input
- input.jpg (175.08 KiB) Viewed 22446 times
black_sire
There was a problem with videocards by AMD/ATI.
Already fix it and released 1.2.2.
Download version 1.2.2 from the site.
irworkshop.com
Fixed. Thanks!
- Tschoepler
Crash
Anyone can help with this issue: viewtopic.php?f=13&t=8224&p=32395#p32395
Mapio crashes Avenue on every shutdown and randomly crashes Avenue while running.
black_sire
IR Mapio updated to 1.2.3
* Fixed crash on shutdown of Resolume Avenue and on change a composition.
+ Added check for equality of versions of the FX's module and Mapio editor.
http://irworkshop.com/blog/entry/23-ir- ... d-to-1-2-3
irworkshop.com
