CONNECT VVVV (PC)+ Arena (MAC)
Godneyo
Post by Godneyo »
Hello There, i would LOVE to connect The Output of Arena running in a MAC OS (Mountain Lion), and send it to a PC running VVVV.
mainly because i would love to manipulate a layout of touchosc in my ipad, with some visuals in resolume, and also generate real/time visuals on VVVV,
Is there a way i could do this?
HerrNieDa
Re: CONNECT VVVV (PC)+ Arena (MAC)
Post by HerrNieDa »
i fear you won't come around a capture card (Blackmagic Intensity or similar models which work with VVVV).
found no things on the web to get this to run via lan or so (you would need a software/client which works as virtual capture device which receives the signal from your pc on your mac over lan)
