4U Resolume step sequencer [Lemur]
Re: 4U Resolume step sequencer [Lemur]
ok... but you see the sequencer buttons in the lemur editor on your computer?
mkobzar
Post by mkobzar »
Hello cosmowe ! Thank you for this setup, it's reason to buy Lemur.
I use your project, but next tune my.
I have one base layer and some other with layer router.
Remap buttons like Flash, Roto - not a problem.
But other, I remap trail button with sequencer, and don't understand how tune fx5step line to effect on layer 1.
I think problem in composition and fx panels global setup.
zhukang
Post by zhukang »
wwww
jeffdodge
Post by jeffdodge »
That's absolutely awesome!!
I'm going to try this out!
thomgee
Post by thomgee »
Hi - This ist hot Stuff, but:
It is not working on Resolume 7 anymore ?!
The Adresses are not working, eventhough i can see them in the Monitor of OSC Settings
the demo-File is noch working in Res. 7
Is there an Update?
Arena 6 & 7
MacOS 10.14.4 Mojave
Macbook Pro 2017
3.1Ghz | 16 Gb | Radeon 560 4GB
have a look at this post: viewtopic.php?f=14&t=11086#p44120 ;)
thomgee
Post by thomgee »
Hahaha, I am right now struggeling with it.
But ist is hard to find out the Mapping - some Effects dont exist or have different names ("Dots")
And the sequences dont really work... Maybe i am missing some pathes...
Does someone has already mapped the new paths?
Some hints or at least the Fields which are to edit...
I go on struggling
If I am successfull - I'll deliver a List or even Template :-)
Arena 6 & 7
Macbook Pro 2017
OSC addresses can be found easily by entering OSC shortcut mapping, and clicking on a highlighted item: https://resolume.com/support/en/osc#osc-addresses
