Resolume with OS X El Capitan
Djtwok
Post by Djtwok »
Has anyone tried it yet ? Does it work flawless ? I need some input before updating.
Macbook pro 13inch mid 2012
www.Soundcloud.com/djtwok
Re: Resolume with OS X El Capitan
It seems to be working fine and I haven't found any problems related to the new OS yet.
Resolume works good.
I have problems with Blackmagicdesign hardware, so if you use any hardware alongside, be sure to check compatibility for them too.
Also check forums for software compatibility, for example adobe aftereffects was not able to start on the betas for a long time, that is now sorted, but you get my point.
